Michael's RV-10 Build Log
Date:  11-14-2005
Manual Reference:  24
Brief Description:  Drilled left tip and mounted strobe pack.
Got the left tip fitted and drilled. Also mounted the strobe power pack. One of the other advantages to the shelf I put in is that I could mount the power pack to the underside so I didn't have to come up with some other backet for it. Hopefully this is far enough from the back of the shelf that I can still mount the AHARS back there.
Left tip drilled.
Left tip drilled.
Strobe power pack mounted.
View of strobe pack mounting from front.
