Michael's RV-10 Build Log
Date:  11-2-2005
Number of Hours:  1.50
Brief Description:  Continued working on support structure.
Well I chucked the rear support in favor of one that is riveted to the bulkhead. This will save a lot of effort and weight. The front is a bit more difficult because of the bulkhead brace. Ideally i could just bend an ear around and rivet it on. Unfortunately I'm using what I have laying around and .125 doesn't bend 90 degrees. .125 is way overkill for this but it's what I have because of the longeron screw up. .063 would provbably be the best. I will need to figure out a bracket or pick up something a little thinner. If I had a TIG welder I could just weld the whole thing up.
New support in place
Three -4 rivets should do the job
Another view showing it level with the longerons.
