Michael's RV-10 Build Log
RV-10
Started some prep on the wing tips
I decided that there are several things I can do prior to the full blown fitting to the wings so I will trim and install the hardware to these.
Almost an inch needs to be trimmed.
Tip lenses seperated.
RV-10 Home
1749
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
530
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
