Michael's RV-10 Build Log
Date:  6-27-2008
Number of Hours:  2.50
Brief Description:  Finished console and some firewall work.
I finished the overhead mount this morning. I also did a little more contouring yesterday just to help the headliner material to conform better. Turned out pretty good but the final judgment is reserved until I put the headliner on. I also put together the oil cooler box. I'm going to go with a little better oil cooler as the general consensus when talking to people that have flown the stock is it could be a little better. This is also confirmed when I talk with Pacific Oil Coolers. I don't know if I will go with a Stewart Warner from them or the one that Alex sells from Airflow Systems. I'll probably go with Alex's as people have reported a drop in temps with his and it is a fair amount less than the SW. I also put the pressure tap on the firewall. Two things with this. First I had yet another nutplate that just would not take the bolt. This is the same problem I had in the tailcone around the trim attach and I'm thinking I had a batch of malformed nutplates. I checked the old nutplate when I removed it and saw no damage from bucking which was my first thought. The other thing is I'm debating which components I want to powder coat in the engine compartment. I was eyeing a powder coat set from Eastwood for a couple years now and finally picked one up because I have an old oven lying around. I want to get the firewall mostly ready to accept the engine so that stuff is out of the way.
Good enough to be covered by headliner
Oil cooler mount
Oil cooler mount
Pressure taps
Pressure taps
