Brief Description: Reconnected controls and adjusted bulkhead fitting
I spent a few hours today finishing up some misc items related to the fuel line work. For one I had to put the control system back in place as it was necessary to remove it to make the work on the fuel system easier. I also replaced the bulkhead washer on the AFP purge line bulkhead fitting for better grip. I thought I was out of the bulkhead fitting washers that came with the kit and so I was using AN970 washers drilled out to the fitting size to fill that role. The AFP purge line was the first I did this way and I discovered I needed two washers. I also added another couple cushion clamps to make sure everything is secure.
