Michael's RV-10 Build Log
Date:  5-21-2008
Number of Hours:  0.60
Brief Description:  Added fans to dash access covers
Before deciding to do the dash access covers I had always planned on adding a pair of fans in the dash to both facilitate cooling and act as low tech defrost fans. They are your standard 80mm computer fans and are about 16 CFM each. I can always add fans with more CFM if needed later.
Hole drilled and fan fitted with a screen
view from underside
view from underside
Finished product
Finished product
