Michael's RV-10 Build Log
Date:  10-29-2005
Number of Hours:  2.50
Brief Description:  Aileron trim and fairings
Started the aileron trim. Nothing complicated, most of the time went into the alodine and prep process. Just waiting on the paint to dry for final assembly, probably tomorrow as I lay a heavy wet coat on to get a nice gloss.
I attached the right elevator fairing about 75%, Once that is complete it only leaves the two HS fairings. I'll probably install some of the lighting and stuff into the wingtips even though they won't be attached for a while.
Aileron trim bracket painted
Right HS Fairing
Right HS Fairing
