Michael's RV-10 Build Log
Date:  10-24-2005
Brief Description:  Attached right flap, started left bottom skin.
Well the right wing is pretty much done. I have heard from other guys that have built more than one RV to leave the wingtips until the wings are attached and the flaps and ailerons are trued so this is what I'll do.
Probably have about 6 hours to finish off the left wing. Most of the short bottom skin is riveted. Once the long skin is on that only leaves the trim kit and attaching the aileron and flap. On this wing I'll set the rigging on the aileron before I put the skin on. Bit of a tight place to work in.
Flap on, not much to it as the actuation is in the fuselage.
Adapter on the pitot to hook up the air line.
Flap and aileron actuated
