Got the right skins ready for alodine. While I was looking at some stuff laying around on my bench I ran across the screws that hold the pitot to the mast. They are standard #6 round head machine screws with lock washers. Well I don't see the point of having four screws stick out in an otherwise smooth surface so I countersunk the holes on the mast and will use some 507-6R6 which are flush head screws. May need to find some with a shorter reach thogh or cut some down. I'll then use locktite on them to make sure they don't back out.
