Michael's RV-10 Build Log
Date:  10-15-2005
Number of Hours:  1.00
Brief Description:  Mounted control unit for pitot
One of the things about the pitot I'm using is that it is actually thermostaticaly controlled. Because of this there is a small control unit that needs to be mounted near the pitot itself. Good thing I decided to move the pitot so far to the outboard part of the wing otherwise I would have need to put in an access panel for this. Instead it only took an hour to throw together a little bracket.
Control unit on bracket
You can see the stand-offs
Riveted to rib
Riveted to rib
