Michael's RV-10 Build Log
RV-10
Continued work on leading edges
Match drilled the right LE and located and drilled for the AoA ports. Began dimpling.
The tiny hole between the 2 larger ones is the AoA port
Dimpling skins
Ribs almost ready
RV-10 Home
1749
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
530
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
