Michael's RV-10 Build Log
RV-10
Sanded and tested left tank
Left tank turned up one leak in a bit of a difficult spot. It's where the forward attach coes into the inboard skin right around the nutplate hole. Should be fun to seal. Just need to put in the AE Fuel Guardian sensors.
The only leak in center of picture
Rear baffle attach points
Tanks sanded
RV-10 Home
1696
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
502
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
