Michael's RV-10 Build Log
RV-10
*EMPANNAGE ASSEMBLY COMPLETE*
Finished installing push pull tube for elevators, installed trim system, attached rudder. Had to replace aft 2 screws on trim assembly attach with AN3 bolts due to difficult with #8 screws.
Elevator push/pull and trim assembly installed
Trim cable routing
Trim cable attached to tabs and adjusted.
RV-10 Home
1728
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
509
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
