Michael's RV-10 Build Log
RV-10
Began disassembly of tail and deburring
Discovered a crack in the F1010 bulkhead. Looks like the drill bit missed the flange hole and bent it around causing the crack. Ordered new bulkhead from Vans
RV-10 Home
1749
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
530
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
