Once again I bounced around a bit between different areas. Primarily I finalized some more of the ignition wiring, torqued and set TC on the port e-mag, and tightened and set the starboard e-mag TC. I didn't torque it down yet as I'm only 90% sure that it is in a good position. Added it to my punch list so I don't forget. Contacted e-mag to swap out the right angle plug boots for the lower plugs as straight will be better.
Now that it's warm I'll be starting on the cowl and adding a 1/2" to make it a little longer. It's a major PITA but 5/8" is a bit too much between the spinner and cowl for me. And honestly I need every fraction of an inch between the throttle body and the cowl I can get.
