Brief Description: Windscreen and throttle bracket
Did the final trimming of the windscreen to fit it. next will be preping the fiberglass and plexiin addition to making the brackets for the lower edge to hold it in place.
I also cut the new bracket for the throttle and mixture controls. It took about 90 minutes to setup the cnc and cut the bracket. My homemade CNC is pushing it's limits cutting aluminum without a more rigid z axis and VFD spindle, and as such the tolerences aren't the best, but it will work fine.
