Michael's RV-10 Build Log
RV-10
Rear side panels and seatbelts
Reinstalled the rear side panels and put the rear seats in to check that the heaters still work ok. Also removed the tunnel access and reinstalled the front heat duct. I also got the replacment SL-30 from Stein but haven't checked it out yet.
RV-10 Home
1812
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
530
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
