Brief Description: Seat wiring and position levers
My seats all have seat warmers in them. The rear seats are fine but the front needed the seat back wires lengthened to reach to the plug points under the seats. The factory covering on the wires was a low quality PVC which was not only really stiff, but also started to crack. So I replaced it with a braided polypropelene wire sleeve which should be superior. I also have the mod that provides a lever to adjust the front seat locations rather than the hard to reach T handle on the sides. I'm using these as a way to mix a power for powder coating that closely matches the panel inserts so I can powder coat them instead of the paint that I have on them now.
