Spent some time wiring up the sticks and ensuring they fit properly. A while back I switched to the Tosten pro grips which have a little more lean back than the standard Tosten grips. This helps with panel clearance which is otherwise a problem with the Aerosport panel. It does give me an extra button that is just below the trigger but I don't have anything setup for it so it's unused for now.
I also need to send the SL30 off to Stein to check it out as I have now confirmed there is no transmit or recieve on the comm side. I won't know if it's the SL-30 or the audio panel that has the problem until I get it checked.
