Spent time today on a couple areas. First I continued work on the panel that holds the oxy, vent, and headphone jacks for the back seats. I mostly finished the pieces that act to isolate the vents from the other areas of the panels and I reinstalled the oxy disto blocks back into the freshly cleaned and conditioned panels. I also removed the actual vents and cleaned them up so I could paint the inside part of them for reinstall. I cleaned up the overhead console and ordered LED bulbs to replace the original filament bulbs. I also cleaned and conditioned the main side panels for the rear seats. I've been slowly going through all the leather pieces, cleaning and conditioning them as it's been quite some time since last done and they need it. Lastly I finished redoing the connections for the back seat headphones in order to allow the metal side panels to be removed. This required me to place JST connectors in line. Not ideal but shouldn't cause any issues and it was the only way to make it work with removeable panels.
I'm no longer adding pictures to the logs directly. Apple went to the HEIC format a while ago now and Kitlog doesn't recognize it. Besides that, most photos are now way too big to be attached to an old Access database like this. It's far easier for me to search my photos by the date of the log entry to find anything relevant.
