Michael's RV-10 Build Log
Date: 12-2-2023
Number of Hours: 3.00
Brief Description: Rear pax trim panel
One of the things I did with the rear seats was add a trim panel to provide a finished feel to where the back seat air vents are. These hold the oxy distribution boxes, a ball vent, and the headset connections. To finish these, I must isolate the air vent from the oxygen below and the headphones above. Hence, the pressurized air is controllable and doesn't interfere with the altitude compensation of the oxy. This area had vexed me for a while, but I finally settled on a straightforward approach of a styrofoam wedge that I will cover with micro, adhere in place, and then put a piece of weatherstripping around it to seal it up. Once these are done, I still need to make a device to open and close the vents. My issue is that I want a push-pull lever that is closed when pushed in, but that will require a cam to reverse the direction. I'll also design and print a trim piece for this, similar to what I did for the oxygen blocks.
