Michael's RV-10 Build Log
RV-10
Spar and rib riveting
Attached rudder horn to bottom rib along with nut plate. Also attached nutplates to rear spar.
Bottom rib with rudder horn attached
Spar with nutplates attached
Stiffners in place
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
