Michael's RV-10 Build Log
RV-10
Oxy and vents
Not a whole lot to report. Basically I ran the high pressure oxy line from the fill station to the tank. I also finished up the forward vents by spraying on the soundproofing material I used in other areas.
Vent and soundproofing
High pressure oxy line
RV-10 Home
1749
Ailerons
Avionics/Instruments
Avionics/Wire
Cowl
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
530
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
