Michael's RV-10 Build Log
RV-10
More closeout panel work
Not a lot this morning. I located and drilled the holes for the rear seat headsets and marked a spot should I want to add power for ANR in the future. I also did some more prep work on the panels for soundproofing.
Headset jack holes drilled.
Taped and ready to be sprayed.
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
