I've kind of got away from regular updates. Gone are the days where I would work in a dedicated mode on the aircraft daily and this was part of the ritual. Going forward I will probably make occasional task updates and put in an estimate of the hours I've spent. Since my last update I've spent a lot of time on the panel which is nearly complete. Most of the instruments have been wired and smoke checked. I've now moved on to the firewall/engine area so i can get as much completed on that prior to riveting the upper deck in place which will make future access difficult at best. Some other items include putting on the sound/heat barrier on the firewall, adding in the ANL fuse for the alternator, finishing firewall penetrations, and some other misc electrical.
