The baggage door goes fairly quickly and I should have it most of the way complete tomorrow. I have a building list of locations that need to be primed/sound dampened and this will be one of those items. I also picked back up a project I stopped a while back when my Dremel quit. I didn't see an easy way to get nut's in place to hold the tail light so i decided to hog out some of the material and fiberglass in a piece of aluminum scrap that could then be drilled and tapped.
Fitting the baggage door.
Basic structure with hinge attached.
Hard to see but there is a piece of aluminum in the bottom of that.
