Michael's RV-10 Build Log
RV-10
Match/final drilled both halves for joining
Finished up all of the drilling and matching up of components and then seperated the two halves again for final cleanup and prep.
Everything drilled.
View of the right side.
The two halves are seperated for final prep.
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
