Michael's RV-10 Build Log
Date:  11-30-2011
Number of Hours:  6.00
Brief Description:  Began panel wiring
So the fun begins. I started this morning by finishing mounting the VP in the new location and as I was going through drawers I found the control module for the low fuel warning system from Aircraft Extras. I'm trying to keep everything on the side of the bulkheads that are fully accessible from the panel side so I got that mounted next to the radio rack. I also started going through the pre-made harnesses that came with many of the avionics to see what's what. I couldn't find the color key for the AFS harness so i spent some time checking about 6 wires to see what pins they were. I also started modifying the TruTrack harness for install.
AE Fuel Guardian mounted
whole bunch of avionics and wire
Started cleaning up pre-made harnesses
