Michael's RV-10 Build Log
RV-10
Completed panel sub assembly
This morning I riveted everything together. Looks good and no problems. On to joining the tail to the fuselage!
View of the assembly before panel is attached.
View of the underside. You can clearly see the rib modifications here.
Completed view.
RV-10 Home
1464
Ailerons
Avionics/Instruments
Avionics/Wire
Elevators
Empennage Assembly
Fairings
Flaps
Fuel Tanks
485
Hat Shelf
Horizontal Stab
Inventory
Lighting
Lighting/Electrical
Systems
Tail Cone
Vertical Stabilizer
Wing Leading Edge
Wing Ribs
Wing Skins
Wing Spars
Wings Assembly
