Michael's RV-10 Build Log
Date:  8-20-2005
Number of Hours:  4.50
Manual Reference:  14
Brief Description:  *WING RIBS COMPLETE*
Drilled holes for conduit and riveted/bolted the ribs to the main spars. I ended up flipping a few of the lower bolts on the left spar because of the additional hole I put in for the AOA tubing. The first inboard three couldn't be flipped because of possible interference with the tank baffles so I left them normal and used some E6000 over the bolt threads as an anti chafe material.
Attached ribs
Attached ribs
Flipped bolt
Flipped bolt
Shoe Goo anti chafe
Shoe Goo anti chafe
