Marlins Web Site
Date:  6-23-2014
Number of Hours:  10.00
Manual Reference:  N/A
Brief Description:  Installed the pitot-static system
Image1 shows the SD-42 BSLF blind rivet installed on the aft fuselage side-skin located at a neutral presurre point on the fuselage.
Image 2 shows the connections to the static port on the right side of the aircraft and the tubing going forward to the instrument panel.
Image 3 shows the connections to the static port on the left side of the aircraft and the tubing vertically connecting to the static port on the right side via a brass tee and horizontally and down connecting to the GRT AHRS.
1 of 2 static ports (drilled rivet)
Static Line from port aft of baggage compartment
Left side static port connections to GRT AHRS
Copyright © 2001-2021 Matronics. All Rights Reserved.
