Marlins Web Site
Date:  12-15-2015
Number of Hours:  20.00
Manual Reference:  Electrics
Brief Description:  Connected wires for both stick grips, trim servos,
After I installed the grips on the sticks, I soldered labeled and soldered each of the wires for the 4-way hat switch (aileron and elevator trim); trigger switch to key the microphone; index finger button to engage/disengage the autopilot; and the two other buttons to either switch the com from active to standby, switch between come 1 and com 2, change several of the GRT EFIS displays, or to view weather and traffic on my Navigation Map displays from my new ADSB in/out receiver/transmitter. I also wired the labeled and crimped the wires for the aileron and elevator trim servos. Finally I designed and built a tray to hold the relays and all the wires going to/from both grips, the roll and pitch trim servos, and the panel indicator lights to show the roll and pitch trim positions. This was very time consuming and hard on my back because the tray and all the wires had to be installed under the floorboard in an accessible panel area.
Stick Grip wires labeled and soldered
Aileron and elevator Indicator wiring
Fabricating relay tray for wiring
