Marlins Web Site
Date: 1-30-2017
Number of Hours: 24.00
Manual Reference: Electrical Systems
Brief Description: Wired GMA 240 Audio Panel to headset jacks & grips
I’ve had to travel to Denver a couple times so haven’t worked on the RV as much as I’d hoped. I did get much of the GMA 240 Audio Panel wiring done and got the headset and microphone jacks connected to the audio panel and stick grips. I also finished the audio inputs for the Marker Beacon and the Angle of Attack Warning System as follows: Completed wiring for GMA 240 Audio Panel Power and Ground (J2402 Pins # 8,9, 10, & 11); Audio Panel Lighting Bus Hi (J2402 Pins # 6 & 7) to the Navigation light circuit; Lighting Bus LO (J2402 Pins # 5) to the Panel lighting Dimmer; Pilot Headset Audio Out Right-Left-Lo (J2402 Pins # 31,16, 1); Pilot Microphone Audio IN HI-KEY IN-LO(J2401 Pins # 33, 34, 35) Co-Pilot Headset Audio Out Right-Left-Lo (J2402 Pins # 4, 3, 2); Pilot Microphone Audio IN HI-KEY IN-LO(J2402 Pins # 32, 33, 34); Com Swap IN (J2402 Pin # 20) from Pilot stick grip. Completed wiring for AOA Pro from the CPU D-sub to the Audio Panel Audio Panel-(J2401 Pin 31) and Aircraft Ground Buss to the Audio Panel Audio Panel-(J2401 Pin 32). Completed wiring for MB10 Marker Beacon Audio Output (Pin 6) to the Audio Panel-(J2401 Pin 21) and Audio Ground (Pin 14) to the Audio Panel-(J2401 Pin 22). Completed wiring for the Elevator and Aileron Relay Deck & Servos to the P2 Main Buss with a 4 Amp breaker and the Elevator and Aileron Relay Deck & Servos to the Aircraft Ground Buss. Daisy-Chained all shield wires to the frame of the audio Panel. Next, I’ll probably run all the wiring from the NavWorx ADS600 (ADSB) to all their respective interfaces.
Daisy Chain shield wires to frame
Pilot Headset and Microphone to audio
Co-Pilot Headset and Microphone to audio
