Brief Description: Verify/Completed all wiring for panel and instrume
Verify wiring for Instrument Lights Dimmer (Marker Beacon/Garmin GNS 430W/Clock Internal Light/Elevator & Aileron trim indicator lights terminate at the NAV Light Switch terminal on the Composite Design breaker. I verified all the wiring and switches for the Panel Lights Dimmer-2 (LC LED Strip Red/White and (Left/Center/Right) Post lights, Map & Baggage Lights. Completed all connections to power, fuses, and grounds.
