Marlins Web Site
Date:  11-1-2007
Number of Hours:  4.50
Manual Reference:  Sec 7; Dwg 15A
Brief Description:  Install Right Wing Electrical Conduit
I used a block of wood with a pilot hole drilled as a template to drill 1/4" holes in each rib. Then I used a 7/8" unibit with three drill extensions to drill out all the finished conduit holes. I deburred and pulled the flexible conduit I purchased from Van's through all the holes. Finally, I sealed each hole with RTV to keep the conduit from chafing and/or moving in the holes.
7/8" unibit with 3 extensions
Drilling 7/8
Drilling 7/8" holes after pilot holes drilled
Conduit installed and RTVed
