Marlins Web Site
Date:  4-24-2009
Manual Reference:  Section 8; Dwg 27A
Brief Description:  Trimming Horizontal Stabilizer for Elevator Swing
After marking the materials to be trimmed off the upper and lower horizontal stabilizer and removing the elevators; I drilled a radius hole and trimmed off the tabs with a shear. I was suprised I needed to cut off approximately an inch on both sides of the stabilizer...since there was nothing in the instructions or the diagrams which required this step. At first I thought I must have messed something up, but after looking through other builders construction logs for a couple hours, I finally found a guy who showed these same type pictures and explained the process he used to remove the excess materials.
Right side of Stabilizer marked and ready for drilling
Radius Hole Drilled to remove Tab
Upper Tab trimmed off
