Marlins Web Site
Date:  8-14-2011
Number of Hours:  4.00
Manual Reference:  Section 6; DWG 7
Brief Description:  Bottom Rudder Horn Fiberglass Install
Final cutouts around rudder horn brace. If I had to do this over, I would not cut as deep as the scribe marks indicated on the fiberglass bottom piece. There is now about an 1/8th inch gap below the rudder horn brace (where the rudder cables attach to) and I cut exactly on VAN's scribe marks. I'll have to do some fill work to finish this piece so there is no gap below the rudder horn brace. I will also need to figure out where to run the electrical wires for the tail light. I still need to drill a 1/4"drain hole in the bottom of the fiberglass, run the strobe light wires, countersink holes at 2" spacing, and install the fiberglass using CS4-4 flush pop rivets. Hopefully I'll get that done tomorrow night.
Bottom rudder fiberglass
