Marlins Web Site
Date:  2-27-2020
Number of Hours:  6.00
Manual Reference:  N/A
Brief Description:  Kroger RV Super-Slider Sunshade Installation
It’s been a long time since I did any work on the RV. My torn bicep is finally healed and I can use my right arm again almost as good as before my injury. I needed to do some paint touch-up work on the canopy frame and the rollover-bar before I installed the Kroger Sliding Sunshade. I was told installation is pretty simple if you can do it before final canopy riveting. The first picture shows me fitting the Sunshade channel to the canopy frame and drilling the mounting holes. Next, I installed the Kroger Sunshade ribs in the order designated in the instructions and bent them slightly to just clear the canopy plexiglass when installed. It was a little challenge to get the fabric mounted on the ribbing but once that was complete, I installed six Velcro-dots with center screws to the rollover bar to attach the Sunshade fabric in its fully extended position. It looks very nice and will definitely be worth the time and expense in bright sunlight.
Installing Sunshade Channel
Fitting Fabric to Slioding Ribs
Shdes Extended with Velcro Tabs
