Marlins Web Site
Date:  6-12-2009
Number of Hours:  4.00
Manual Reference:  Sect 8; DWG 27A
Brief Description:  Fitting the Vertical Stabilizer--Aligning the VS
I temporarily clamped the Vertical Stabilizer assembly to take measurements from the tip of the vertical stablilizer to both tips of the horizontal stabilizer. I then adjusted the vertical stabilizer until the measurements are equal and the stabilizer is truely vertical. (Note the 1/4" offset of the VS to counteract propwash P-factor.) Next I will drill the bolt holes through the stabilizer and the F-712D up-elevator-stop.
VS Temporarily Clamped
1/4" Offset
Another pic of the offset
