The only additional information in addition to the previous pictures is you need to be very careful to get the rigging correct; i.e. make sure the elevator is clamped in the neutral position, and the elevator bellcrank is perfectly vertical. This is done by trial and error adjusting the rod-end bearings until all the rigging is correct.
