Marlins Web Site
Date:  4-18-2009
Number of Hours:  4.00
Manual Reference:  Section 8; Dwg 27A
Brief Description:  Drilling the Elevator Horns
When I built the elevators and the horizontal stabilizer, I didn't fit them together by drilling either the top or bottom elevator horns. These horns are best dirlled with the elevators mounted to the stabilizer. The holes must be exactly perpendicular to the horns or when the bolt installing the pushrod is tightened, one horn will be pulled forward and the other aft, mis-aligning the counterbalance arms on the elevators. Since I can't do this on a drill press, I decided to clamp the counterbalance in place and drill two holes for two bolts; one for the push-pull pivot and one to keep the horns parallel.
Elevator Horns without holes
Side View of Elevator Horns and Pushrod
Drilling Left Elevator Horn Pivot Hole
