Marlins Web Site
Date:  3-31-2009
Number of Hours:  1.00
Manual Reference:  Sect 8; Dwg 36A
Brief Description:  Dual Brake lines installed
I fabricated the 1/4" aluminum tubing that goes from a bracket on the firewall to the brakes. In the first picture, the two lines on the left are the brake lines, the other line on the right is the fuel line from the valve to the engine. The 2nd picture shows these brake lines as they go to a bracket on the firewall. The 3rd picture is the brake resevoir installed on the engine-side of the firewall.
Fabricated tubing to brakes
Brake lines to firewall bracket
Brake resevoir installed
