Marlins Web Site
Date:  3-30-2009
Number of Hours:  8.00
Manual Reference:  Sect 8; Dwg 36A
Brief Description:  Install Bonaco Fuel Lines Valve to Wings
The teflon steel braided Fuel and Brake Lines I ordered from Bonaco arrived yesterday. I snaked the new fuel line from the fuel selector valve through a new hole in the main spar bracket and under the gear mount. Both fule and brake lines go through the 2nd hole from the top on the gear mount. The brake line is aluminum tubing that I fabricated. It goes down to the brake through the floor near the gear mount. The fuel line goes out the side of the fuselage. All the lines from Bonaco cost $240 but they were worth every penny. The next 12 pictures show these lines installed.
Bonaco Fuel Line Left Wing
Bonaco Fuel Line Right Wing
Fuel Lines and brake lines
