Marlins Web Site
Date:  3-15-2009
Number of Hours:  3.00
Manual Reference:  Sect 8; OP-21
Brief Description:  Installing fuel lines from boost pump to engine
The next thing to do is install the fuel lines from the electric boost pump and fuel tank selector through the firewall to the engine. The new plans eliminate the need for a gascolator and an electric primer, so all had to do was fabricate a firewall strengthening plate to mount the fuel line fittings onto. The first picture is the mounting plate and fitting on the "engine-side" of the firewall. The 2nd picture is the other side of this elbow-fitting on the "cockpit-side" of the firewall. The 3rd pic gives a perspective where the line will go. It comes out of the back side of the fuel pump assembly, underneath the mounting plate and forward with just one 90 degree bend into this elbow.
Firewall strengthening plate & fitting
Fuel line elbow inside the firewall
Overall perspective
Overall perspective
