Marlins Web Site
Date:  3-6-2009
Number of Hours:  3.00
Manual Reference:  Sect 8; OP-21
Brief Description:  Assembling Aerflow Performance Fuel Pump
The Airflow Performance high pressure fuel pump looks fairly simple. The pump is made up of an assembly of a pump motor, a swing check-valve to prevent backflow when you switch tanks or the engine pump is doing all the pumping, a relief valve for over-pressurization, and a maintainable filter. All I had to do with the plate is align it to the center console plate, drill and install 6 nutplates for screws and paint it. The first picture are all the parts temporarily assembled. The 2nd pic is the mounting plate painted. The 3rd pic is the filter assembly mounted onto the plate with a clamp and some fabricated rubber pads to protect it.
Partially Assembled Parts
Mounting Plate Painted
Filter installed
Filter installed
