Marlins Web Site
Date:  1-30-2009
Number of Hours:  4.00
Manual Reference:  Section 8; pp 8-15
Brief Description:  Rig the Control Column to the Ailerons
The WD-610 control column, WD-611/WD-612 control sticks, and F-665 control column pushrods are adjusted at the rod end bearings on the W-730 bellcrank assemblies. The first thing you have to do is align both control sticks so they are both parallel in their neutral positions (perfectly aligned vertically and horizontally). I did this by adjusting the F-665 pushrod and bellcrank assembly that connects both sticks together while aligning both sticks using a speed square and my Husky electronic level. With both stick controls perfectly parallel to each other; vertical (90 degrees) and square; I was ready to set my ailerons in their neutral position and rig the connecting pushrod and bellcrank assemblies.
Squaring up both control sticks
Rigging Right Stick to Neutral Position
Jig to set Left Stick to neutral position
