Marlins Web Site
Date:  1-5-2009
Manual Reference:  Section 8; Dwg 38
Brief Description:  Leveling the fuselage to prepare for wing sweep
With the main spars on both wings pinned using the 8 fabricated drift pins I bolted the spars in place using common 7/16" x 5" hardware bolts in the top and bottom of each spar. Then I carefully shimmed the sawhorses under the tail and nose of the fuselage. I also bought a Husky electronic level with an electronic alarm that beeps when the unit is perfectly level. If you are doing this by yourself, it's the only way to go. It's critical to level the fuselage, both laterally and horizontally, using the top surface of the F-718 longerons between F-704 and F-705 as a datum surface.
Electronic Level on  Seat Rail
Alarm sounds when it's perfectly level
Electronic Level on Fuselage Side Rails
