Marlins Web Site
Date:  1-3-2009
Number of Hours:  7.00
Manual Reference:  Section 8: Dwg 11
Brief Description:  Attaching Wings to the fuselage
Here are some pictures of the shop rearranged to get both the wings and the fuselage to fit into my shop. You can see it's a very tight fit but there is room to maneuver. You can also see the new sawhorse stands adjusted to the correct height to attach the wings to the fuselage. The second picture shows the drilled holes for the pitot tube and all the wires coming from each of the wings. The last picture shows the left wing attached to the fuselage. My wife Susan helped me attach both the wings. The fit was extremely tight and each wing took us about 3 hours to get it in place and get the drift pins installed on top and bottom.
Rearranged shop and new sawhorse stands
Holes for wiring and Pitot Tube
Left wing attached
Left wing attached
