Marlins Web Site
Date:  8-24-2008
Number of Hours:  4.00
Manual Reference:  Section 8; Dwg 33
Brief Description:  Electirc Flap Assembly Fabrication
Electric Flap actuation is standard on the RV-7A. The power comes from a sealed motor/gear drive assembly between the seat backs, driving the flaps through a welded steel actuator and pushrods connected to the inboard end of the flaps. Image 1 is a picture of the assembled actuator push rod end. The plans call for a safety wire hole to be drilled in the end of the push rod.
Next I installed the flap actuator in the baggage compartment using bearing bolcks on the uprights in the center of the actuator and on the ends.
Safety Wire Holes drilled in the flap motor actuator
Second hole drilled into the side housing
Bearing Blocks on the center of the flap actuator
