Brief Description: Assembled and mounted control column
It took me 10 hours to assemble the control columns and rig them. The 17 3/8" on center rigging of the control arm to each of the two sticks was more like 18". I had to take it all apart several times until I finally got it perfect. Movement is smooth and I shimmed all the play out of the assembly with small washers over the ferrals. Even though it took me about 8 hours more than it should have, it turned out very good. Next I'll work on the electric flap motor assembly.
